Another fuel pump question - NCRS Discussion Boards
  • Jeff P.
    • 797
    5CBEF1F1-547F-458E-BBFB-5E04F0FE3450.jpg486C2C07-1784-4586-A592-9168AC4F0042.jpgC6132432-2B0C-456D-95C0-1212473D77F2.jpg
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Gary B.
    • July 31, 1979
    • 926
    Re: Another fuel pump question
    The casting configuration is like what I have seen on late model cars. "H" is 1968, I've been told. If you follow the calendar, "F" would be 1992?
    The ears where the mounting bolt goes through, have a flat and an extra rib. During 1973, they added the flat on the casting, the rib came later.
    Gary B
    • Jeff P.
      • 797
      • Francais D.
        • October 8, 2016
        • 91
        That fuel pump looks great , i was thinking of having what i was told to be original fuel pump that came with car. But now i do not think it is , the number is 298R40658 and it has 2 holes in the body in each of the places you have 1 hole. Does anybody know what this date is?
        • Gary B.
          • July 31, 1979
          • 926
          Up through 72, maybe into early 73???, the fuel pumps should be shaped liked this around the bolt boss. I've seen an early 73 with a flat of the bolt boss, but no rib on it. I think that came later in the year. Even later, the number of weep holes changed. New update to the 68-69 and 70-72 TIM&JG's will have better descriptions and pictures.
          Gary Bosselman
          • Francais D.
            • October 8, 2016
            • 91
            Thanks that picture is close to the one i have. Is there a chart some where to decipher the dates
            • Gary B.
              • July 31, 1979
              • 926
              pretty easy...
              H = 1968
              I = 1969
              J = 1970
              K = 1971 so on, so on....
              Gary B
              • David L.
                • July 31, 1980
                • 3310
                I did a lot of research on AC fuel pumps years ago.
                EXAMPLES of AC Fuel Pump stampings:
                "FF40433" (June 1966), Early 1967 Corvette (VIN # 183)
                "HH40669" (Aug. 1968), 1969 Camaro Z28, "V0912DZ" (Sept. 12, 1968)
                Dave
                https://www.forums.ncrs.org/showthre...el+pump+dating
