'67 With 9 Days Between Body Build and Final Assy - NCRS Discussion Boards
  • Daniel B.
    • November 28, 2016
    • 13
    Does anyone have an explanation for how a '67 St. Louis body car with a trim tag date code H22 (March 22) would legitimately have an official production date 9 days later on March 31, 1967? The March 31 date is per the NCRS Shipping Data Report. I am understanding there is typically only 1-3 days between the body build date and the final assembly production date. As further information, the engine stamp (TO32IJE) shows March 21 production which I understand is not unreasonable.
  • Mark L.
    • 550
    Re: '67 With 9 Days Between Body Build and Final Assy
    Daniel, if you provide your order number I will double check the data. Have you had the car judged at a Regional?
    • Daniel B.
      • November 28, 2016
      • 13
      Thanks Mark. The Shipping Data Report was order #15852. The St. Louis Chapter VIN and Trim Tag Decoder agrees with the March 31, 1967, on the NCRS Shipping Data Report. The car has not been judged.
      • Keith B.
        • September 15, 2014
        • 1575
        pictures of the trim tag and vin tag?
        • Reba W.
          • 932
          Easter weekend was March 24-26. I don't know if that affected plant operations or not. Or the car could have needed some sort of repair before completion.
          • Mark L.
            • 550
            Daniel, the recheck shows all is correct with the original report.You may want to confirm that the trim tag is correct for the car.
            • Jack M.
              • March 1, 1991
              • 1138
              Besides the repair possibility that Reba noted, I recall reading mention of 'dealer financing' issues causing a production delay... then again, my recollection might be inkorrect. In any event, I like the engine assembly date fitting more in line with the LATER (3-31) production date.
              • Roy S.
                Past National Judging Chairman & Concours Team ******
                • July 31, 1979
                • 1022
                What is the body number on your car and body style?
                • Mike D.
                  • July 31, 1996
                  • 303
                  Is your car a convertible? My coupe is H22 and VIN 14478.
                  Mike Doty
                  Intermountain Chapter Judging Chairman
                  Region VIII Director
                  • Daniel B.
                    • November 28, 2016
                    • 13
                    H22 Build Trim Tag for March 31 final assy.
                    • Daniel B.
                      • November 28, 2016
                      • 13
                      Body number is 6815. I posted a photo of the trim tag.
                      • Jack M.
                        • March 1, 1991
                        • 1138
                        That image is fairly small/low-res for a critical evaluation... other may have a different opinion.
                        For comparison, some of the 67 Trim Tag info I've saved, from St Louis Convertibles:
                        H22 - S6829 - 194677S11452X
                        H27 - S6879 - 194677S11470X
                        H30 - S7000 - 194677S11512X
                        Does your VIN fit in with this group?
                        • Daniel B.
                          • November 28, 2016
                          • 13
                          My VIN is slightly higher but close to the VIN with the H30 body.
                          • Michael H.
                            • December 1, 1987
                            • 724
                            Dan,
                            Post a high resolution picture of your stamp pad for comments. It was nice meeting you the convention as I mentioned at the convention with the engine assembly date of 3/21 being 1 day before the body build date of 3/22 it's almost impossible as the big blocks were built in Tonawanda. I suspect the original engine may have had a mechanical issue which would explain why the NCRS shipping date shows 3/31 as the cars original engine was being replaced. Typically you see 1-6 weeks before the body build date on Big Blocks engine assembly date. I have seen small blocks with 1-2 days before body build date as the those engines were built in Flint.
                            You have a great looking car.
                            Mike
                            • Daniel B.
                              • November 28, 2016
                              • 13
                              Originally posted by Michael Hanley (12271)
                              Dan,
                              Mike
                              Thanks Mike. Here is a higher resolution photo than the one I shared at the convention. The car was restored 15-20 years ago. I've owned it for 5 years. It was great meeting you in Mobile. Thanks for the advice you gave. Hope you avoided COVID. I came home with a mild case. Feeling normal now but still testing positive and remaining isolated this week.
