The drain hole in tire well of my 61 Corvette Has been glassed over. Can someone please give me the measurement of the hole that I need to drill? Also, is there a source for the translucent plastic flanged plug? Thanks! Mark
61 Trunk Drain Hole
Re: 61 Trunk Drain Hole
The plug is not reproduced.
However, it is the same plug(by part#), used for the late 1966 and all 1967 used to plug the threaded reinforcement bracket weldnuts to mount the optioned shoulder harnesses(A85). The plug is removed and the bolt is threaded in to hold the harness.
I had 4 from 2 '67's I added harnesses to. Iirc, I'd given away 3 to 61/62 gents and may have 1 left. I'm away from the shop but will check when I return. But not for a while.
More info Here.
Rich- Top
- Top
Mark, The email through this site may have gone into your junk/spam folder.
Click on my user name above. Click Send Email button. Send me your phone# and physical mailing address. I'll get your email address in it so I can reply with details.
Rich- Top
P2180030.jpg- Top
- Top
