69 Rear bumper mounting hardware- which washer is correct? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    I'm looking at the rear bumper mounting hardware for my 69 coupe as I check boxes getting ready to have my car judged. I noticed in the AIM that there was only one style washer used for all the rear bolts, GM part # 9419276, but the body shop that did the paint and installed the bumpers used two different styles, a standard zinc plated flat washer, and a black oxide (?) plated serrated washer. See attached pics. Trying to figure out which is correct. Thanks for any help you can give.
    Mike
    Re: 69 Rear bumper mounting hardware- which washer is correct?
    Originally posted by Michael Leonard (46610)
    Guys,
    Mike
    [ATTACH=CONFIG]113278[/ATTACH][ATTACH=CONFIG]113279[/ATTACH][ATTACH=CONFIG]113280[/ATTACH]
    Michael------
    The black phosphate, serrated washer is correct.
    • Michael L.
      • December 15, 2006
      • 1387
      Thanks Joe.
      • David B.
        • March 1, 1980
        • 687
        You might want to research part # 9419276
        • Leif A.
          • August 31, 1997
          • 3607
          This is what AMK is showing for a #9419276 washer.
          Washers - Flat .46 to 1.0 ID .48 ID X .88 D X .06 TK FLAT WA PHOS. 12 pk Phosphate & Oil (OVD) 9419276 B-11754
          Leif
          • David B.
            • March 1, 1980
            • 687
            AMK is correct on dimensions, GM refers to it as narrow outside series Type B Flat washer.
            • Floyd B.
              • November 1, 2002
              • 1046
              Page UPC-14-B1 shows 3 washers used for attaching the bumper braces and bumpers:
              #5: 9419276 - P. Washer
              #6: 103328 - L. Washer
              #11: 1362249 - Spl Washer (serrated)
              The 1362249 serrated washer (see pic below) is used under the bolts and nuts that attach the outboard braces to the frame. All other locations use the 9419276 & 103328 washers together. As best I can recall, this configuration matches original cars I have seen. However, I find it interesting that the previous page in the AIM does not indicate use of the serrated washers on the outer braces of the front bumpers. The use of these washers is called out in the TIM&JG, pg 208 and I can't think of an instance when I didn't see them on known original cars. In the AIM, these would be UPC-14-A2, #14. The AIM describes these as #9419277, P. Washer. I do not believe this is correct. I think #14 should be a 1362294 serrated washer or similar.
              "Drive it like you stole it"
              • Gary B.
                • July 31, 1979
                • 926
                I just hit the like button on Floyd's post, but nobody can see it.
                Gary Bosselman
