Alternator date code number - NCRS Discussion Boards
  • Roger H.
    • September 27, 2020
    • 85
    The alternator on my 1965 needs to be replaced or restored. The car has a build date of January 31, 1965. The alternator has the code 4H27 which I believe translates to August 27, 1964. I assume it's original to the car, but wonder if an August alternator belongs in a January car. I'm sure my friends at NCRS can enlighten me. Thanks in advance.
  • Leif A.
    • August 31, 1997
    • 3607
    Re: Alternator date code number
    Roger,
    The date is within the six month window of date acceptance, so you should be fine. Post up a clear picture of the numbers on your alternator and we can tell you if it's a re-stamp. Sounds like you may have your original.
    Leif
    • Roger H.
      • 85
      Thanks, Leif. I bought the car in 1973 when it was only eight years old. I've never changed the alternator, so I believe it is original.
      • Keith B.
        • September 15, 2014
        • 1575
        Is it a common 693 37 amp unit or the more uncommon 42 or 63 amp unit?
        • Bill M.
          • 1317
          Roger do you want it restored? or just repaired. Most of the time all you need is brushes and change the bearings while you are at it. blow out the windings and spray with insulating varnish and you are good to go.
          • Leif A.
            • August 31, 1997
            • 3607
            Roger,
            If you're going the restoration route, I can personally recommend Ken Bruno @ Ken Bruno Motorsports. He has done my original alternator and my original starter. Absolutely first class workmanship.
            We specialize in Corvette and other GM Muscle Car Show Quality Delco Alternator, Starter and Generator Restorations.
            If you just need your alternator repaired (no stamps on diodes, etc), you should be able to find a local alternator/generator repair shop to do the job if you're not comfortable doing it yourself.
            Leif
            • Roger H.
              • 85
              Keith, it's the 37 amp unit.
              • Roger H.
                • 85
                Nothing under the hood is show quality. I really just need it repaired, but it would be nice to have it restored to NCRS specifications. I'll consider Ken Bruno. Thanks for the information.
