66 Vent Splash Shields?
Re: 66 Vent Splash Shields?
Paul when you say vents, do you mean the 3 side fender openings rearward of the front wheels?
If so, yes, each side underneath there should be a triangular shaped flat shield, Inner.
There are also Outer shields with a rubber weatherstrip stapled to them.
They're shown inconspicuously in the AIM, buried in there somewhere. I'll find it in a while.
Edit.... found it.... (note lots of whitespace in images below)
Inner - Attaches to frame and under floors to brackets. The left side bracket also holds the accelerator pedal to the floor.
UPC 1 BOLT WELD SHEET A6
Item 1 L & R
Outer - Attaches between frame and inner skirt.
UPC 11-13 SHEET A2
Item 3 L&R
===================- Top
