History
- Problem first showed as headlights opening shortly after starting the car. At first they responded and closed using either the override or headlight switch.
- Then it began to require a fair vacuum (> 2K, closed throttle, most success was going down a steep grade) to get them to close.
- Curiously, at night they would reliably close when lights shut off. This would happen even when engine shut off first. Then only the left closed one time. Now neither.
- Somewhere along here, the wiper door began to open on its own, and now nothing will convince the lights or wiper door to close (other than as referenced above)
