1964 Upper Kick Down Rod For 300 HP Powerglide - NCRS Discussion Boards
  • Thomas R.
    • October 17, 2011
    • 76
    Looking for what the dimension (i.e. length) and photo of 1964 300 HP/Power Glide Upper Trans Kick Down Rod. The Carb is an AFB 3720S. The current rod on the car is not correct the Carb on it now is 3721B. Can anyone provide this info and were a correct rod can be had. Thanks
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 1964 Upper Kick Down Rod For 300 HP Powerglide
    It appears that Zip, Paragon and Top Flight are all out of stock for your particular upper kickdown rod. I can't help with the dimension but a picture of what you want is below.
    Leif
    • Thomas R.
      • October 17, 2011
      • 76
      Leif, Thanks for feedback. I have a Paragon Upper Kick Down Rod. It is just like your photo. I tried to attach aaaaaa photo of my linkage set up but,it won't load. Anyway, my Rod is 11" long on the 3721B AFB Carb. I'm trying to put on the correct 3720 S AFB and the current Rod is off and rubs on Carb throttle lever. The Paragon Rod is 12 5/8" long. The end threading does not go down the shaft far enough for the swivel to meet the carb throttle lever. I would like to see a 63 to 65 300 HP power Glide linkage set up. I hope, someone out there can help. Any more thoughts would be great. Tom
