Hi everyone. I searched "valve cover restoration" and the most recent thread I found was almost ten years old. I wondered who is doing an NCRS-quality restoration these days. Thanks in advance.
Aluminum valve cover restoration
Re: Aluminum valve cover restoration
I would try vapor blasting the aluminum first to see the result. Vapor blasting is usually all is needed to restore aluminum.- Top
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Joe
thanks i wanted to get my 67 intake done but i am concerned with the length of time for the process. i drive the car until just about the first snow. i dont want to leave the motor open all winter. There is some one on LI whe does dri ice cleaning. Ill have to speak to them to see how it works.- Top
I had a 1963 B-W transmission case done by vapor blasting. There is a guy somewhat near who has been doing it for many years, and his work is exceptional.
Turnaround was a couple of days. He know what he's doing, and usually does motorcycle engines and similar, though he has done some Corvette parts prior to mine.
Here is a photo of the transmission after I assembled it.
I had him do a couple of midyear valve covers too, but no picture here. I can post one later if you wish.
They look great.Attached FilesVice-Chairman (West), Michigan Chapter NCRS
Vapor blasting is a surface refinishing process used to clean and restore surfaces. Instead of dry abrasive media (used in sandblasting), it uses a combination of water, compressed air, detergents with finer and gentler media to remove oxidized metal and corrosion.- Top
Bill, as Joe stated not the same. I feel that vapor blasting is the best procedure to restore aluminum back to its original appearance.- Top
Hi Patrick--if it's not too much trouble, I'd like to see a photo of the valve covers. Not just for me but for the record...Thanks.I had a 1963 B-W transmission case done by vapor blasting. There is a guy somewhat near who has been doing it for many years, and his work is exceptional.
They look great.- Top
