French Locks - NCRS Discussion Boards
French Locks
  • Paul A.
    • April 21, 2021
    • 227
    French Locks
  • Leif A.
    • August 31, 1997
    • 3607
    Re: French Locks
    Paul,
    Inboard half shaft universals use lock washers. The flange end (at the trailing arm) use French locks. They need to be torqued to 70 lb ft and, yes, the standard steel french locks will twist/deform before reaching 70 lb ft. Use the stainless steel French locks and you won't have that problem.
    Leif
    • Paul A.
      • April 21, 2021
      • 227
      Re: French Locks
      Leif, As stated my vette has neither! I will install lock washers in inner universals and SS FL on outer. Although 70 lbs seems like a lot for those small bolts. Thanks for clearing that up.
      • Paul A.
        • April 21, 2021
        • 227
        • Leif A.
          • August 31, 1997
          • 3607
          Re: French Locks
          Paul,
          Picture below of the half-shaft u-joint grade 8 cap bolts and heavy duty lock washers.
          Also, a picture of the torque spec for the outer flange grade 8 bolts from the AIM.
          Leif
          • Leif A.
            • August 31, 1997
            • 3607
            Re: French Locks
            Paul,
            Just as an FYI, this is a pretty handy torque list.
            Corvette Torque Specifications
            1963 – 1982
            Brakes:
            Caliper Mounting Bolt - Front..........70.........5/8
            Caliper Mounting Bolt - Rear ..........70.........5/8
            Caliper Housing Bolts - Front.........130........13/16
            Caliper Housing Bolts - Rear ..........60.........5/8
            Rear Suspension:
            T-Arm Front Toe-In Shims.............50+*.......5/8 & 11/16 nut
            Spring Retainer To Rear End ..........70.........13/16 bolt (de arch spring)
            U-Joint (inner) U-Bolts...................15.........9/16 nut
            U-Joint (inner) Caps......................30.........9/16 bolt
            U-Joint (outer) Flange Bolts............75.........5/8 (use locks)
            Strut Rod (Inner) Camber Bolt .......70*........3/4 nut
            Strut Rod (outer) Shock Mount .....75+* .......15/16 nut
            Shock Absorber (upper) Bolt ...........60..........5/8 & 11/16 nut
            Shock Absorber (lower) Nut ............40..........3/4
            Bearing Housing to T-Arm ...............30..........9/16 nut
            Spindle Nut ...................................100+. .......11/16
            Warning: If the assembly was not properly set-up, tightening the spindle nut
            will load the bearings and cause imminent bearing failure.
            Wheels:
            Rally Wheels (steel).........................75...... ....3/4
            Optional Wheels (aluminum) ...........80*.........3/4 (re-torque at 100 mi.)
            Front Suspension:
            Upper A-Frame Bushing Bolt .........35*........9/16
            Upper A-Frame Align, Shim Nut......50.........11/16
            Lower A-Frame Fr. Mtg. Bolts ........70.........5/8
            Lower A-Frame Rear Mounting......100........7/8 & 13/16 nut
            Steering Arm to Spindle ................70.........3/4 Nuts (63-68, 11/16)
            Ball Joint (upper) .........................45+........3/4 nut
            Ball Joint (lower) .........................75+........7/8 nut
            Ball Joint (replacement bolts) .........25.........1/2
            Carrier:
            Front Brackets to Frame ...............65.........5/8 & 11/16 nut
            Front Brackets to Housing ............50+........5/8 & 11/16 nut
            Strut Rod Bracket Bolts ................35.........9/16 (use locktite)
            Rear Cover Bolts..........................50....... ..5/8
            Filler Plug ....................................20
            + plus additional torque when necessary to align cotter pin hole
            * tighten bushings only when arms are at riding height
            Leif
            • Paul A.
              • April 21, 2021
              • 227
