Am I wrong to assume the torque converter attachment brackets that mount 6 places on the face of the converter be in a flat plane so they will mate to the flywheel plate? My brackets are at a slight angle away from the centerline of the converter. This means that if the bolts are tightened down fully, the flywheel becomes distorted at each mounting hole.
54 6cyl torque converter mounting to flywheel
Re: 54 6cyl torque converter mounting to flywheel
I don’t know if this will be helpful but here is a photo of mine…Attached Files- Top
I have a photo of the flexplate and it sure doesn’t LOOK distorted at the attachment points.There is one attachment point at about 4:00 or 5:00 in the photo where , given the lighting, I think any deformation would be visible. As an aside to this thread perhaps someone can tell me if I should have six of the attachments.Attached Files- Top
Tony
Yours is a passenger car and or truck fly wheel
Same for the OP
Here is my experience the passenger car and truck are larger in diameter
The Corvette is smaller
I will measure them tomorrow - I have several in the shop
The larger fly wheel will have problems with the starter
It will not engage !
The passenger car / truck starter is different
I will post up a photo of the two1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
This is an engine I did for 1954 #21 - Real deal - note the starter (starter and solenoid are Correct)
This is another engine I did and it is a truck engine
Note the starter angle and position - see how the solenoid is tilted
Hope this helps1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Chris, Thanks for the photos of the flywheel. I have the one with the cutouts. Getting back to the problem of the Torque converter mounting brackets, If you place a straight edge across them, are they flat or do they show some angle NOT parallel to the face of the converter?
Norm- Top
I will pull the convertors I have out - Yours look correct - I dont see any issue - Let me look at mine1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
