Colonoscopy! - NCRS Discussion Boards
Colonoscopy!
  • Jack J.
    • July 31, 2000
    • 640
    Colonoscopy!
  • Mark E.
    • April 1, 1993
    • 4498
    Re: Colonoscopy!
    Year and transmission type?
    Are you saying that with the engine running in neutral and the clutch depressed, it doesn't shift into any gear and it doesn't grind while attempting this?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jack J.
      • July 31, 2000
      • 640
      Re: Colonoscopy!
      Mark, 1964 with a Muncie. Second question - YES
      • Mark E.
        • April 1, 1993
        • 4498
        Re: Colonoscopy!
        My first thought is the clutch isn't fully disengaging. But this is usually accompanied with grinding. You might check for this anyway.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Jack J.
          • July 31, 2000
          • 640
          • Mark E.
            • April 1, 1993
            • 4498
            Re: Colonoscopy!
            Does the clutch fully disengage? The friction point should be with the pedal a couple of inches above the floor (exact spec is in the manual).
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Brian M.
              Infrequent User
              • June 2, 2008
              • 17
              Re: Colonoscopy!
              4625046-muncie-won-t-go-into-gear-at-idle-it-will-when-engine-off-and-when-driving.html
              This may help.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Re: Colonoscopy!
                Jack,
                You've had several threads regarding the clutch/bearing/fork problems. Some who are reading this thread may not know your previous efforts. It may have been better to continue where you left off.
                You never got back to us in This Thread.
                Did you test any of this with the bell housing out?
                • Mark E.
                  • April 1, 1993
                  • 4498
                  Re: Colonoscopy!
                  Jack,
                  Absolutely! One thread per issue, please.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Jack J.
                    • July 31, 2000
                    • 640
                    • Bob R.
                      • June 30, 2002
                      • 1595
                      Re: Colonoscopy!
                      Jax
                      if you had the flywheel resurfaced it could cause the problem you are having. You may have to add shims to move the flywheel closer to the clutch. This will give you more adjustment on the rod. I think the rod used on a 66 is a little longer substituting would also fix your problem.
