I have the 9 leaf spring disassembled and would like to restore the broadcast code on the tension side of the bottom spring.
I think the number on the attached photo is "NBL" on the top and "07882" on the bottom. Could someone confirm these numbers as being reasonable? Any advice about how or whether I should try to repaint the code is appreciated.
Thank you.
Thank you.
