In the final prep for the Frisco Regional Meet and have a 1967 427 / 390 that won’t fire. In going through the operations check. The car ran fine but noticed a slight oil leak from the filter canister. After addressing the leak, the car will not start.
The car turns over perfectly and there is fuel. Checked the spark and there is none. Pulled the coil lead off of the distributor cap and turned the car over and there is no spark when holding the distributor end of the lead near the ignition shielding. Verified that there is power to the + side of the coil. There is also power on both sides of the ballast resistor.
Tried a new coil and the results above were the same. Any thoughts or help would be appreciated to get this car going…..
