Help with 1964 Stingray heater box refurbishment. - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5258
    Re: Help with 1964 Stingray heater box refurbishment.
    Originally posted by Michael Garver (49693)
    Anyone know if all C2 heater boxes are identical?
    I believe there were three designs in 1963. I think the last 1963 design lasted through 1967.
    There were two designs of the short snout on the left side. The second design was to accommodate the A/C air hose. The snout is 1963 only.
    There were two designs of the Y duct. The second design was to accommodate the last design of the inside heater box. The Y duct was 1963 only.
    • Michael G.
      • November 12, 2008
      • 2155
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 831
        Mike, The 63 Heater boxes are unique due to the open hole at the drivers end. 64-67 are identical.
        If you want to put a late 63 box into a 64-67 car you will need to block the hole.
        • Michael G.
          • November 12, 2008
          • 2155
          • Ron L.
            • July 31, 1998
            • 111
            For restoration of the box, does one just scrub it up? Or, were the boxes painted black?
            • Ron L.
              • July 31, 1998
              • 111
              John - any advice on how to remove the doors from their attached rods?
              • Harry S.
                • July 31, 2002
                • 5258
                Ron, some are spot welded in. You need to cut the weld with a Dremel. After you restore the parts, dry fit them in the box. When you are comfortable they fit, JB Weld them in place.
                Agree with Joe, if you are using a 63 box in a 64-67, block off that rectangular hole in the picture below.
                • Bob R.
                  • June 30, 2002
                  • 1595
                  • Ron L.
                    • July 31, 1998
                    • 111
                    #24
                    Bob - I need to do a couple fiberglass repairs. Any way to create black fiberglass?
                    Thanks - Ron
                    • Ron L.
                      • July 31, 1998
                      • 111
                      #25
                      John - nice job on the flappers. Either I misplaced it, or it was not included in my Paragon rebuild kit, but I did not get material for the gate you are holding in the picture. Did your kit come with that piece? Also wondering if it was split, as in cleaning out the old it is just tucked under the raised edges and does not cover the entire piece? Finally, any thoughts on what material I can use?
                      Ron
                      • Harry S.
                        • July 31, 2002
                        • 5258
                        #26
                        Thanks - Ron
                        Actually no, What you do is mix black dye in with the resin. As a last step, put some of the dye on a rag and wipe the area to make the finish the same all over. If I can find the dye, I'll post a picture.
                        • John W.
                          • December 15, 2015
                          • 61
                          #27
                          Ron, My 64 convertible is a fuelie, so my side emblems are different.
                          Sorry.
                          John
                          • John W.
                            • December 15, 2015
                            • 61
                            #28
                            Sorry.
                            John
                            • John W.
                              • December 15, 2015
                              • 61
                              #29
                              Ron, I cannot claim any credit for the flapper/door. It was part of the rebuild kit from Zip. I just needed to drive in a new shaft. The new shafts were still so tight, no tack welds were required to keep them in place. The “sealing material” is just very thick, black felt and it is sandwiched and riveted between the metal sides of the door. I think I went with Zip over Paragon as the rebuild kit included a few extra pieces/parts.
                              Regrds, John
                              • Bob R.
                                • June 30, 2002
                                • 1595
                                #30
