I have already looked at Eaton and they don't make a standard spring for my '67 coupe, so looking for recommendations for front coil springs that are as close to OEM as possible. Thanks.
'67 coupe with AC- need recommendations for front coil springs OEM look
Leif
Top Flight 2017 Lone Star Regional- Top
Re: '67 coupe with AC- need recommendations for front coil springs OEM look
Leif, I can always count on you for great advice and help. I know that the BB with AC takes a heavy duty spring, but didn't realize that my SB with AC would also. Thanks.Garry Barnes #18531
'67 Lynndale Blue Coupe- National TF, BG
'67 Sunfire Yellow Coupe- 4 Star Bowtie,
Gary,
When I looked up the changes way back, one was the springs. The HD springs can cause cracks and A/C doesen't add that much weight. The comp is 37 lbs and the condencer and evap aren't that much weight. Well maybe the 3 lb charge of freon was it!! I went back to std pprings for a better ride.
Dom- Top
Dom, thanks for your input. I could not find the standard springs on the Eaton site. I believe the standard springs have 12 coils. Do you happen to know what the standard springs part number was from Eaton? Did you get yours from Eaton? I see Zip carries what appears to be an as OEM spring that might have come from LIC. Many of the guys bought them from LIC when they were in business.Garry Barnes #18531
