65-67 battery location(s) - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Gary
  • Ed S.
    • August 6, 2014
    • 1377
    Re: 65-67 battery location(s)
    Gary, according to the GM ADA spec manuals, for the 65 & 66 model years, the battery location was "right rear engine compartment" for all engine options. It does not mention or provide info regarding location of battery for AC or no AC cars.
    Ed
    • Lawrence M.
      • February 1, 1995
      • 404
      It's been 47 years but I'm pretty sure my 1965 L78 had the battery on the driver's side.
      Larry
      2002 Z51 Convertible
      1969 L46 Convertible
      • Gary B.
        • February 1, 1997
        • 6979
        • Bill M.
          • 1317
          My L 78 had the battery on the drivers side with the battery fender panel. My 67 C 60 also has the battery on the drivers side same panel.
          • Leif A.
            • August 31, 1997
            • 3607
            ALL factory A/C cars had the battery on the driver's (left) side, as did the '65 big block. ALL other small blocks and big blocks had the battery on the passenger (right) side. Access panel built into the left (driver's side) inner fender well.
            Leif
            • Mark M.
              • October 21, 2008
              • 333
              Leif you are correct except the access panel was on all A/C and "65" 396 cars on the left side rear wheel well for battery access.
              • Gary B.
                • February 1, 1997
                • 6979
                Originally posted by Leif Anderson (29632)
                ALL factory A/C cars had the battery on the driver's (left) side, as did the '65 big block w/o A/C.  ALL other small blocks and big blocks had the battery on the passenger (right) side with an access panel built into the rear of the inner fender well.
                • Kenneth B.
                  • August 31, 1984
                  • 2084
                  TOTALY confused. ALL my AC C-2'S SB & BB has the battery on the drivers side with the inner fender bolted in to remove the battery. All non AC cars had the battery on the passenger side with NO inner fender removable panel.
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    Ken,
                    You are correct.
                    So, the answer is not as complex as I expected. To summarize:
                    All 65-67 cars with C60 (AC) had the battery on the left (driver’s) side. All 65-67 cars without AC had the battery on the right (passenger’s) side; with one exception: ‘65 L78 cars without AC also had the battery on the left.
                    Left side batteries had the removable access panel; right side batteries did not.
                    Gary
                    • Leif A.
                      • August 31, 1997
                      • 3607
                      Absolutely correct...shouldn't type before my first cup of coffee...I knew that. Fixed my above post...thanks.
                      Leif
                      • Owen L.
                        • September 30, 1991
                        • 838
                        Originally posted by Gary Beaupre (28818)
                        Leif,
                        What does “&nbsp” mean?
                        Gary
                        &nbsp is an HTML browser code for "nonbreaking space", which has to do with not allowing a new line to separate words/numbers/symbols. These codes are usually hidden from display. You will see this in a page display when part of the HTML code has been broken in some way.
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          • Gary C.
                            • April 1, 1998
                            • 375
                            1965 L78 Battery location.
                            • Kenneth B.
                              • August 31, 1984
                              • 2084
                              And GM didnt give up on this design. My 85 also had this design.
