I have an original 65 battery, lead acid. Can I cut it open and insert a newer smaller battery inside and pass judging?
Cut open a lead acid battery? Possible inert a gel or agm inside?
Tags: None
- Top
Re: Cut open a lead acid battery? Possible inert a gel or agm inside?
Bill,
Send Tim Gilmore an email. Tim did a Tech Session for the Texas Chapter on cutting the bottom out of a C2 battery and inserting a new battery.
Gary
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Thank you,Tim, I reviewed your pics, did you cut open a restoration battery or an original AC Delco lead acid battery? I have the original battery from 1965, I assume it has a bunch of lead acid cells and dividers. I guess if I am careful, I can cut out the bottom, clean out the center section and somehow attach cables to the top terminals? looking for advice from someone that has done that?
Bill- Top
Two folks from our seminar did bring batteries that were original, and they were cored out. That raises an entirely different set of circumstances as far as acid and lead. The two we opened up during our seminar were Restoration Batteries with a sealed battery inside. I have an original never used 1967 battery and someday I may open it up and remove the plates.- Top
Here's a link to 2 articles that appeared in the Summer 2011 issue of The Restorer
https://www.ncrs.org/restorer/Battery%20Article.pdf- Top
Thank you Vinnie, that's what I was looking for.
Bill- Top
Bill, We had a seminar on this at Fort Pitt Classics years ago.Thank you,Tim, I reviewed your pics, did you cut open a restoration battery or an original AC Delco lead acid battery? I have the original battery from 1965, I assume it has a bunch of lead acid cells and dividers. I guess if I am careful, I can cut out the bottom, clean out the center section and somehow attach cables to the top terminals? looking for advice from someone that has done that?
Bill- Top
John, Yes we had a seminar on cutting open a reproduction battery and replacing the internal agm battery already set up inside.
My question is has anyone cut open an original equipment battery, cuting out the internal cells and attaching a cable to the original posts, I am sure I can do it, just looking for surprises I might encounter?- Top
William,
Yes, people have cut open OEM batteries and installed a smaller AGM battery inside, and connected to the OEM terminals. What you will be faced with shouldn’t be called surprises. The presence of toxic metals, toxic fumes, and perhaps acid (if the OEM battery was ever used), is a near certainty. Be careful.
Gary- Top
Agree.
For C2, new DELCO service replacement battery loses 12 Originality (and no Condition) points - out of 4500.
Pick your poison on cost vs more "authentic looking" units.
Standard Deduction Guidelines are generally a gift on maintenance items.
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
- Top
Mike, I used this battery and it fit perfectly.Attached Files- Top
- Top
