I (almost) hate to even ask this question but....... alignment of the distributor dimple - assuming we are talking about original parts here, 64 L76 engine - all advice previously given is that the dimple should "line up" with the rotor contact.
My question is, should it be a perfect alignment - or is it off a bit when properly installed. My dimple is on the same side as the rotor contact but..... it is about 10 degrees off dead center alignment. It is not on the back side - looking at the dist with the rotor installed - when the rotor points to the 12 o'clock position the dimple is closer to the 1 o'clock position - they are not "perfectly" aligned. Is this alignment correct? BTW - the hole / roll pin is directly between 2 gear teeth. See the attached pic.
Thanks for the answer.
