1969 Rear Body mount inspection plate question.
Re: 1969 Rear Body mount inspection plate question.
Not sure what the finish should be on the fasterners for a 69 but I am betting the material they used to seal the plates was a product like what is available now produced by 3M. It is a strip calk, comes in different colors, black, grey that I know of. Not terribly expensive - a box will last forever - if you are doing a complete restoration might as well buy a box for $30 - you need it for some applications behind the door panels - and a few other places too.
Ed- Top
If you have the AIM for a 69 get the part # for the screws and enter just the part # in the search field of this forum. There is a high probability that someone sometime asked the same question - if that screw (and part #) is mentioned in any previous thread it will come up in a list of threads - usually someone asks about the finish on a fastener. You can also do a search for the part number and finish, like "99999 finish". My guess is that it was zinc - but verify that. This search technique is great - use it for just about anything.Ed- Top
Joseph,
The screws are plated clear zinc (silver) and the black caulking that Ed referred to is the sealant used to keep out water/moisture. The plate itself was dip painted with black paint."SOLID LIFTERS MATTER"- Top
