1962 oil pressure sending unit - NCRS Discussion Boards
  • Roger Z.
    • December 1, 1988
    • 23
    Can someone explain or send me to a site that would identify this unit
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 1962 oil pressure sending unit
    Roger,
    Not exactly sure what you're asking about. There is no such thing as an oil pressure sending unit. There is a copper plated steel line that runs from the engine block to the back of the oil pressure gauge...that's it.
    Leif
    • Frank C.
      • August 31, 2003
      • 170
      Roger, I am attaching pictures of what Leif is explaining. If stock, you should have a hard line that is approximately 1/8 inch in diameter that connects directly to the engine block near the distributor then runs through a grommet in the firewall and then to the oil pressure gauge. Hope this helps, Frank
      Frank Clark
      U.S. Army Retired, current serving DoD Civilian
      C1 1962 300hp, 4spd. Black/Fawn
      C2 1966 Coupe, L79, A01, C60, J50, M21, N40. Silver/Black
      C20 1966 Custom Camper, L30, J70, M49, N40, G60, Saddle/White
      C20 1966 Custom Camper, L30, M49, N40, G60, Saddle/White
      • Mike M.
        • May 31, 1974
        • 8365
        oil press sendinguins were used on chevy pass cars of the late 0s and on. no c-1 or c-2 vets used electric sending units. mike mccagh
