New Leaf Spring liner - NCRS Discussion Boards
  • Ed D.
    • December 1, 1990
    • 329
    After about 30 years and a long Road Tour from NJ to the National in Mobile, I have decided to have my 1972 trailing arms rebuild. While I am under there I figured I would rebuild my original leaf spring. Are there any liners that fit or are better than others?
    Ed
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
  • Larry M.
    • January 1, 1992
    • 2688
    Re: New Leaf Spring liner
    Quanta liners are probably the best available. Visit their website.
    Larry
    PS: For trailing arm rebuild, use Bair's or Gary Ramadei.
    • Ed D.
      • December 1, 1990
      • 329
      Thanks Larry, plan on using Bair's for the TA as I have their shipping containers. I will check Quanta liners. Any suggestions on liner assembly?
      Ed
      Ed DiNapoli
      • Joe R.
        • July 31, 1976
        • 4547
        Stick with Bair's on the TA's AND LINERS!
        JR
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Ed, Make sure to measure spring total thickness at the differential mounts before, and then after assembly with new liners, which are often thinner. It could affect the 4 bolt lengths and you may need to shorten the 2 forward bolts.
          Also, when using a new spring center bolt, check head height as replacements are typically too high.
          Rich
          • Larry M.
            • January 1, 1992
            • 2688
            Rich
            Excellent advice.
            Larry
            • Ed D.
              • December 1, 1990
              • 329
              Is is typical to have to trim the liners to fit?
              Ed
              Ed DiNapoli
              • Bob I.
                • November 9, 2006
                • 265
                I had to trim the liners from Quanta, also six months ago I enquired on another set of liners and they were out of stock.
                Bob
                • Joseph W.
                  • February 20, 2022
                  • 368
                  Since we're talking about leaf spring liners, I thought this may be of interest.
                  I was able to come across some NOS liners and measured the thickness. I compared the thickness to a set of liners from Eaton (leaf spring manufacturer).
                  The NOS were .0450" thick and the Eaton were substantially thicker at .078"
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    Joseph,
                    Over the years people have reported a substantial variability in the thickness of the liners. Including differences between GM production liners and GM service replacements.
                    Here is info from two posts from the archives:
                    Gary
                    • Joseph W.
                      • February 20, 2022
                      • 368
                      Thanks Gary,
                      In other words, they are all over the place in thickness!
                      I was super excited to have found some NOS liners. I noticed there is a difference in the actual composition of the NOS and the Eaton liners.
                      The Eaton appear to just be extruded plastic?
                      On a side note, would you mind if I PM you regarding a leaf spring question?
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        Joseph,
                        Easier to send me an email to gsb1966 at-sign comcast dot net
                        Gary
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          The NOS were .0450mm thick and the Eaton were substantially thicker at .078mm
                          • Joseph W.
                            • February 20, 2022
                            • 368
                            Sorry about that! Not sure what I was thinking
                            • Joseph W.
                              • February 20, 2022
                              • 368
                              Originally posted by Gary Beaupre (28818)
                              Joseph,
                              Gary
                              Resending to email. Thank you Gary
