I spent one summer on an automotive-related assembly line, and quickly learned that you figured out every shortcut you could. Corvette assembly was no different. I recently sent a picture of these 68-72 wiper door retainers to Gary Bosselman and asked why they have the "staked" area on top. His reply was that they looked like they had been hit with a chisel and hammer. So we ruminated on that, and came up with this: The easiest way to align the wiper door assembly was to set all three mounts (4 nuts and studs, 2 screws total) to the highest point, and tighten the assembly there. Then, if either side or the middle needed further alignment, the line worker simply whacked at it with hammer and chisel, lowering it to the proper level. No doubt you did it that way on your early C3, so that it wasn't over-restored, right?
wiper door brackets and retainers (2).jpgwiper door brackets and retainers (1).jpgwiper door brackets and retainers (4).jpg
