Ok...so down the rabbit hole I go...
Primary question pertains to the valve at the top center of the box. Wanting to replace it while I am in here but challenges determining what it is and where to get one.; Seems to me it is a temp control valve but only place I have found it is on Doc Rebuild heater vac chart; Not in AIM, not on Zip, nor Paragon catalog/diagrams, nor Corv Central, nor Doc Rebuild. Any intel on this one? If I can't get it replaced can it be restored? Not sure it works or not but this is a "while I am in there" thing.
Second question pertains to same part...how the heck does it come out??? There is a cotter pin inside holding the end of the stem to the valve flap....beyond that simply appears press fit. Really can't see a way to get to the cotter pin. The aluminum back plate of the box is partly screwed on partly riveted...so maybe need to drill out rivets and re-rivet?..no idea why the mix and match fastening. Or maybe just remove screws and see if I can bend back the plate? Or hit that pin that goes through the box with some PB and bang it out?
Once I get all that sorted out and have valves/actuators off, plan is to give the box a nice EvapoRust bath to deal with all the rust....then get it all rebuilt, new seals, etc.
I mention the rabbit hole...cuz removed heater box initially to replace heater core being as I had the radiator out anyway. Core seems fine but good idea nonetheless given it's age. And box has no seals left at all. and blower motor works as far as I know but not correct and I have correct (part and date) one to go in. But that led to complete heater vacuum replacement...led to headlight and wiper door override switch replacement....led to...well you get the idea.
