I opened a Pandora's Box when deciding to replace the rubber brake hoses on my 67 roadster. I was not planning o rebuilding the calipers until until I found the brake fluid having a rather maroon look to it. Also, I had to drain the silicone fluid I had in the system, which was working fine, as it was the old formulation. Now, I am pretty much rebuilding the whole brake system. New Master Cylinder and new seals and boots in the calipers, in preparation to putting DOT3 back into the system. I hate using the DOT 3, as I live in Florida and DOT 3 absorbs condensation pretty quickly here.
I have the calipers apart and ready to put back together. I have not found any torque specifications for the bolts that hold the caliper halves together ( front or rear if they are different ), or the mounting bolts to the frame brackets. Could use some help here!
