C2 radiator
Re: C2 radiator
Keith. That's good to know! It is frustrating to pay $1300 for a new C2 radiator and get a 3-point configuration deduction when it is pretty easy to exhibit the appearance of that obvious feature. TonyRegion VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
Original member of the Kansas City Chapter, est'd 07/11/1982.
Member: 1965 and 1966 National Judging Teams
Judging Chairman--Kansas City Chapter.
Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
- Top
Re: C2 radiator
DeWitts will put the clap marks in the Radiator but they told me that you have to specifically request it when you place your order.- Top
Re: C2 radiator
I still have my original 63 radiator. With all the hullabaloo concerning the clamping marks I went and inspected my original.
With magnification I could see them and only with magnification or blowing up the picture. They were so light as to be almost invisible.
The bung where the top hose attaches was different than the original 63. The inlet may match other years perfectly, that I don't know.
Otherwise it was perfect. No issues and no leaks.- Top
Re: C2 radiator
Tony, what is your process for replicating these clamp marks? Ron- Top
Re: C2 radiator
Bill-------Joe, would you know why the 70 - 72 LT-1 had copper while most 63 - 72 had aluminum radiators?
To me, the copper radiator was probably heavier and perhaps more expensive, so why specifically use it for just a relatively few vehicles in production? Even the Special Performance 350 LT-1 (racing package) 70 - 72 ZL-1 had aluminum radiators ...
I believe the copper/brass radiator has a higher heat rejection (i.e. cooling) capacity than the aluminum 3155316. In addition, 1970-72 Corvettes with THM-400 and/or C-60 also were equipped with the copper radiator. This was for 2 reasons: first, the higher cooling capacity and, second, the fact that the THM-400 cars used a transmission cooler integral with the radiator. The aluminum radiator did not have provisions for a transmission cooler.
1970-72 ZR-1 used the aluminum GM #3007436. This radiator had a higher cooling capacity than the copper/brass or the aluminum 3155316.
By the way, not all 1970 LT-1 were equipped with the copper/brass radiator. Some early cars had the aluminum 3155316. I don't think there was a substantial difference in cooling between the copper/brass and aluminum 3155316.In Appreciation of John Hinckley- Top
Re: C2 radiator
Here ya go...
I marked them:
- Top
Re: C2 radiator
As expected, the original 'factory marks' are more subtle and casual than the perfectly manicured marks in the latest offering from DeWitt. Thanks for posting the pictures.- Top
Re: C2 radiator
as critical is the radiator is towards the enjoyment of the car and the time spent judging is nil, I rather have the part look very close and perform flawlessly- Top
Re: C2 radiator
I'm very pleased with my DeWitt radiator that is coincidentally the same 63 F date as Harry shows in his pictures. The DeWitt overflow tank is also a very nice piece that happened to get damaged when they shipped it so they sent a replacement at no charge and said to keep the one that was dented. Excellent customer service from the new 'corporation' that bought them.- Top
