Compatibility of DOT 5 with modern brake piston seals - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Gary
    Regarding DOT 5 compatibility, there are some recent, informative postings on the Corvette Forum that Jim Lockwood made me aware of, including this one:
    https://www.corvetteforum.com/forums...ake-parts.html
    • 15573
    Re: Compatibility of DOT 5 with modern brake piston seals
    The brake caliper rebuilding parts seem redily available, but the master cylinder kits (either manual or power) seem to be unobtainable at this time.
    • Gary B.
      • February 1, 1997
      • 6979
        • 15573
        Thanks for the tip. I hadn't thought of that way.
        • Bob I.
          • November 9, 2006
          • 265
          • Gary B.
            • February 1, 1997
            • 6979
            Bob,
            Do your existing caliper pistons take lip seals? Or O-rings?
            Gary
              Originally posted by Gary Beaupre (28818)
              Gary
              Gary------
              Given that DOT 5 brake fluid is compatible with a fairly large variety of brake system elastomeric materials I've got to wonder what is the other seal material the brake parts rebuilders use? And, how much cost can be saved by using seals of such material?
                • 11608
                Gary------
                Not only that, with as many as Lonestar uses and could likely sell, they could have them made with rubber that wouldn't be affected.
                I would think that warranty costs for cheap seals would be higher than any difference in price.
                • Gary B.
                  • February 1, 1997
                  • 6979
                  Gary------
                  Joe,
                  I initially thought it must be a cost issue. But as an example of costs, you can get a Raybestos lip seal kit for one rear caliper via Amazon Prime for $11.87. Muskegon Brake sells a rear lip seal kit for one caliper for $14.95. And the Muskegon kit might come with the DOT 5 warranty void disclaimer. So, I’m perplexed.
                  Gary
                  • Bob I.
                    • November 9, 2006
                    • 265
                    Gary,
                    The calipers are lip seal, Lonestar rebuilt them approximately 10 years ago no leaks so far.
                    Bob
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      Originally posted by Bob Imhoff (46494)
                      Gary,
                      Bob
                      • Richard G.
                        • July 31, 1984
                        • 1715
                        Without any thought or knowledge of compatibility or sealing materials I rebuilt the brake system on an C10 truck using DOT5 fluid. This was over two years ago. I did have my share of leaks. Especially when incorporating stainless lines in the build but none were at the rubber sealing surfaces.
                        I have put over 500 miles on the truck and have had zero issues with leaking or function of the brake system.
                        Guess if luck it what it takes I have had some.
                        • Gary B.
                          • February 1, 1997
                          • 6979
