62 327 motor and T-10 trans. ?? - NCRS Discussion Boards
  • Joseph R.
    • August 19, 2018
    • 45
    Hello, A friend bought a 1941 Willys Coupe a while back and is looking to get some info on the motor and trans in the car.
    I did some research and I believe it a 62 327 and T10 trans. I don't believe this was a transplant from a Corvette, but I enclosed some pictures and someone can provide a accurate ID. I can get some more pictures I just tried to provide some of numbers for a reference.
    Thanks, Joe
    TRANS:
    MOTOR:
  • Terry D.
    • May 31, 1987
    • 2690
    Re: 62 327 motor and T-10 trans. ??
    That's better, according to my book an SA suffix is a passenger car motor, 250hp with air.
    • Joseph R.
      • August 19, 2018
      • 45
      I didn't see VIN on either the trans or motor, is that typical?
      Thanks, Joe
      • Patrick B.
        • August 31, 1985
        • 1986
        Yes, only Corvettes and high performance Chevies, like 409’s had vins.
        • David B.
          • March 1, 1980
          • 687
          Trans case cast 3782212 and T10-7B extension housing is '61 Warner 4 speed. probably PN 3792621 wide ratio 2:58, 1:89, 1:51, 1:00, 2:61 reverse if it had a metallic tag it probably would be A-A
          • Harry S.
            • July 31, 2002
            • 5258
            David, do you know what a QQ​ tag is?
            • David B.
              • March 1, 1980
              • 687
              Q-Q is assembly PN 3819115 it is also a wide ratio 2:54, 1:89, 1:51, 2:61 reverse same as above. The difference comes in with the 1st & 2nd, 3rd. & 4th. levers retainer clutch gear brg. etc. etc. can provide #s if you want.
              • Harry S.
                • July 31, 2002
                • 5258
                David, here is why I asked.
                • Joseph R.
                  • August 19, 2018
                  • 45
                  Is there any value to either the motor or trans?
                  • Joseph R.
                    • August 19, 2018
                    • 45
                    I guess there's little value unless specifically slated for a performance option or corvette related?
                    Thanks, Joe
