First time gravity bleeding brakes - NCRS Discussion Boards
  • Anthony C.
    • March 21, 2022
    • 207
    Hi all , can I lift the rear wheels one side at a time and gravity bleed caliper while keeping the front wheels on the ground .. I know the sequence R/R, L/R, R/F, L/F thank you
    • 6940
    Re: First time gravity bleeding brakes
    Tony, you should be able to lift each wheel and bleed, remove master cylinder cap and lift the wheels only as much as you need to crawl under car. Make sure you have jack puck inserted as not to damage body panels.
    • Bill B.
      • August 1, 2016
      • 303
      Hi Anthony,
      I don't see why not. As long as the master cylinder is higher than the caliper being bled, it should work fine! I do it that way too, jacking and removing one wheel at a time. For gravity bleed, I do recommend tapping the caliper assy a few times with a rubber mallet to dislodge any (if any) trapped air bubbles. If using the pressure or pedal bleed method, the higher velocity of the fluid helps to disperse any bubbles without the need to tap the caliper.
      Bill Bertelli
      Northeast and Carolinas Chapters Member
      '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
      • Anthony C.
        • March 21, 2022
        • 207
        I have a 70 planning on using a 2x4
        • Mark E.
          • April 1, 1993
          • 4498
          Depending on the vintage, it may be just as easy to lift the entire car then bleed vs. lifting each corner as you go. This also gives you the opportunity to inspect and lube the chassis.
          Regarding wheel sequence, see https://www.forums.ncrs.org/showthre...Old-Wives-Tale
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Anthony C.
            • March 21, 2022
            • 207
            Originally posted by Bill Bertelli ok thank you bill (62632)
            Hi Anthony,<br />
            <br />
            ok thank you Bill
            • Anthony C.
              • March 21, 2022
              • 207
              thanks mark
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                If you haven't gravity bled the rears yet.....
                I do This.
                Rich
                • Anthony C.
                  • March 21, 2022
                  • 207
                  I do This.
                  Rich
                  Thank you Rich I have done them yet .. your video is very helpful.
                  • Anthony C.
                    • March 21, 2022
                    • 207
                    Thank you would you know approximately each wheel should take to bleed
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11302
                      I've done both rears at once, probably a hour or so total. I just plan other tasks while they bleed, but close by. You need to top off the master so keep a close eye on it.
                      Rich
