Hi , my dealer invoice on my 75 says G95 highway axle ratio however cannot find it in my NCRS specifications book . Does anyone know the ratio
Axle ratio question
Tags: None
- Top
Re: Axle ratio question
Hi 4 speed .. spec book does not list ratio 67B1C8E4-F3DA-4AB9-9948-DD7559DBDABC.jpeg- Top
That would be the RPO code, I think. The AW is what might be stamped on the rear end. However, I don’t see G95 listed as a 75 RPO code in my limited resources. I did see it listed as economy axle ratios on other years in the later 70’s.- Top
I have not .. this is the dealer invoice 5A01A4A4-2182-4E43-ADB8-DC07F3914F2A.jpeg- Top
- Top
If your car is an automatic the G95 "highway" axle ratio should be 2.73:1. If you have a 4 speed a highway axle ratio was 3.08:1. Highway axle ratios were only available with the base engine. Highway ratios were not paired with the optional L82 engine.Ed- Top
Anthony
What is source of your dealer invoice?
Is GM original source, or is this a reproduction copy?
Can't find "G95" in my Parts Book RPO Code list.
DaveJudging Chairman Mid-Way USA (Kansas) Chapter- Top
