1964 capacitors - NCRS Discussion Boards
1964 capacitors
  • Ron L.
    • July 31, 1998
    • 111
    1964 capacitors
    Is there a list out there of all of the 64 capacitors and their OHM ratings?
  • Jim L.
    • September 30, 1979
    • 1805
    Re: 1964 capacitors
    Capacitor values are not expressed in terms of Ohms. They are rated in units of Farads. In particular the capacitors found in autos and used for electrical noise suppression are small and rated in units of microFarads.
    • Donald H.
      • November 2, 2009
      • 2580
      Re: 1964 capacitors
      If you look in your AIM in section U69 you will find all of the capacitors except for one. The other one is in the alternator and you can see it at the back of the alternator. If I recall correctly the alternator capacitor is 0.5 microfarad.
      The AIM has the part numbers for the others. If you google the part numbers you may be able to find the microfarad ratings for all of them. For instance, the capacitor on the turn signal flasher is part number 3839756 and I found a picture of one which was marked .47 MFD
      Don
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • 15610
        Re: 1964 capacitors
        Don't forget the distributor "condenser", which is actually a cap, but the archaic name stuck for the one inside the distributor. From memory it's 0.23 microfarad.
        • Ron L.
          • July 31, 1998
          • 111
          Re: 1964 capacitors
          Thanks all for the help and reference.
          • Donald H.
            • November 2, 2009
            • 2580
            Re: 1964 capacitors
            I just looked and found 8 or 9 including the one in the alternator.
            There are 3 capacitors on the back of the gauge cluster
            1 on the fuse box (turn signal flasher)
            1 on the coil
            1 on the voltage regulator
            1 on the heater blower
            1 on the vent blower
            Don Harris
            • Gary B.
              • February 1, 1997
              • 6979
              • Ron L.
                • July 31, 1998
                • 111
                Re: 1964 capacitors
                Yep - that's what I found in the AIM. In researching the number on the web, I found all of them to be either .47 MFD or .50 MFD with the exception of the heater blower fan which I am still researching.
                • David B.
                  • March 1, 1980
                  • 687
                  Re: 1964 capacitors
                  If you have access to a Chevrolet radio parts catalog, I believe they will all be listed there. Heater blower motor (condenser) PN is 3833336.
                  • Ron L.
                    • July 31, 1998
                    • 111
                    Re: 1964 capacitors
                    Thanks David. According to the 1964 AIM, the heater blower capacitor PN is 3847975 for the non A/C.
