Hello everyone,
As usual, looking for advice from those who have been there and done that.
I was able to find a correct manifold for my 1973 LS4 automatic car. I had the carburetor restpored professionally and it is so nice, I cant just put it back together the way it was. Anyway, I have the correct intake home, stripped it down and cleaned it with a brush and simple green. I was going to sandblast it, but I thought grit would get everywhere and later might end up in the engine, plus its not the best for the machined faces. My next thought was way back when we would use a caustic thermal bath (hot-tank) and it did a good job of removing even the carbon in EGR ports. I dont think that process is done anymore because of the environmental problems it posed. This manifold was purchased off Ebay, so I know nothing about its past life. I was hoping to thoroughly clean it so when its put on the engine I dont add more whatever into the engine.
How do you folks normally clean something like this?
Should I remove the riveted on heat shield from underneath so whatever crud is under it gets cleaned away as well?
As always, thanks for your time and i appreciate the help / advice
Tom
Tom
