I removed the aftermarket headers and side pipes on my 67. I have acquired the correct set of exhaust manifolds to return to under car exhaust as original. My question is, I have a set of new studs, three long and three short, which size goes to which manifold. I can't differentiate from the AIM. I'm assuming long on RH for heat riser?? Gary
1967 Big block exhaust manifold studs
Re: 1967 Big block exhaust manifold studs
You are correct.I removed the aftermarket headers and side pipes on my 67. I have acquired the correct set of exhaust manifolds to return to under car exhaust as original. My question is, I have a set of new studs, three long and three short, which size goes to which manifold. I can't differentiate from the AIM. I'm assuming long on RH for heat riser?? GaryLeif
Top Flight 2017 Lone Star Regional- Top
