Call it what you prefer - radiator supply tank, recovery tank, surge tank... it's the long black tank with radiator cap, mostly hidden on the right side of my BB with A/C. Copper/brass construction.
As you can see in the photo, the top surface of the filler neck is "malformed." I have no idea how this would have happened, but the result is that there is a very poor seal between the filler neck and the secondary seal of the cap. If the radiator "burps" for whatever reason, fluid spills out around the cap as well as out the overflow hose.
Any suggestions as to how to prevent this? I'm reluctant to try to bend the distorted surface back into shape and risk more damage to this $400+ part. I wonder if sealant that remains pliable after curing could be applied top of the neck. I've tried a cap that has a rubber secondary seal, but that doesn't completely eliminate the problem. Any suggestions for a sealant that would remain pliable and resistant to antifreeze and heat?
Mike
Mike
Good idea. I'll see what I can find.
