Valve Cover Retainers and Spec Hi Perf - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 663
    Two unrelated questions.
    Just curious why some engines they used valve cover retainers and others not?
    Also, I see some language about a Spec. Hi. Perf engine in 1969. Just want to confirm that is NOT the L46? Appears that refers to the LT1??
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • 15610
    Re: Valve Cover Retainers and Spec Hi Perf
    I don't understand what you mean by "valve cover retainers, although stamped steel valve covers
    The '69 L-46 was considered a SHP engine as is the LT-1 which was not available until the 1970 model year.
    For '70 the L-46 might be referred to as SHP with hydraulic lifters and LT-1 as SHP with mechanical lifters. This would be consistent with the terminology in the parts catalogs used to describe the '65 L-79 and L-76, respectively.
    • Keith M.
      • January 17, 2021
      • 663
      Duke,
      Check out this link which covers both my questions. This is an example of valve cover retainers. Also, in various documentation sources, parts catalogs (as in this link) it sometimes stipulates something like "w/Spec Hi Perf". I just was not clear that the L46 was such.
      https://www.paragoncorvette.com/prod...r-retainer-kit
        • 15610
        Those were used on some engines with stamped steel valve covers. The page says 66-81 base engines, but that may not be the complete list. Others needs to chime in. They weren't used on SHP small blocks with aluminum valve covers because the bolt bosses and rails are much stiffer than the stamped steel valve covers.
        I recall buying valve cover gasket sets that included little gaskets that matched the plan form or those "retainers" that I just threw away since they weren't required on my 327/340 that have "Corvette" aluminium valve covers.
        I recall F5000 engine builders used plain steel valve covers and what looked like small leaf springs under the bolts that spread out the load over two to three inches either side of the bolt, and it's my understanding that they were production on Corvair engines.
        • Larry E.
          • 1652
          Here is a picture of what Duke is talking about. Picture is a Traco Trans-Am Camaro engine. BTW>Duke I do indeed remember going to Road America to watch the F 5000 with drivers like Andretti/Redman/Unser. Those lightweight cars would just roar
          down the straights at R/A. Valve Covers where Chevy Orange. Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Keith M.
            • January 17, 2021
            • 663
            Ahhh....so their purpose was to spread the pressure across the valve cover lip creating a better, more even pressured seal.
            • Leif A.
              • August 31, 1997
              • 3607
              And, to help deforming the thin metal edge/hole of the valve cover.
              Leif
              • Chris T.
                Infrequent User
                • August 31, 1986
                • 28
                Yes, as stated, originally used on Corvair valve covers. They were adopted by enthusiasts to help with valve cover leaks on small block V8's. P/N was 3850874.IMG_1707.jpg
                • Steven B.
                  • June 30, 1982
                  • 3976
                  I remember those little gaskets too Duke! A long time ago. I threw mine away too.😊
                    • 15610
                    I went to the Can-Am and Trans-Am races at RA when I was a grad student at the U. or Wisconsin Engine Research Center in '69 and '70. By the time I got to CA in the mid seventies the Can-Am was pretty much gone from the cubic dollars invested by Porsche in the 917s, but F5000 was a great and more affordable series.
                    I recall at a F5000 race at Riverside, sometime in the mid-seventies, Mario when out solo to do a few hot laps and try to set a course record, which he did probably eclipsing a record set by Donahue in a 917 with what was basically a souped up version of the engine in my SWC.
                    Many may not remember that the first Long Beach GP was F5000 not F1, and the hot setup was a Lola T-332 with a 5L Chevy SB, stock block and (full race ported) heads, with a IR injection system and racing exhaust system. They reputedly made about 500 bhp and revved to 8000/8200. F1 was the following year, and I recall they were just marginally faster than F5000.
                    I recall Brian Redman won that initial LBGP driving Jim Hall's Boraxo sponsored Lola T-332.
                    F5000 was a great series. It evolved into a "revised" Can-Am using past F5000 cars with envelop bodies, and I recalled it faded away due to the late seventies '"oil crisis".
                    Look a those exhaust ports on the Traco TA engine. Wow! They were probably done by Valley Head Service, and I think they are still around. This must be a '70 version since it's wearing a single 4-bbl carb rather than the 2 x 4 cross ram system.
                    • Larry E.
                      • 1652
                      Pulled up a past thread from our "Master" Joe Lucia>>
                      Larry
                      • Richard F.
                        • September 30, 1981
                        • 498
                        Attached is the Fel Pro version of the O.E.M. reinforcement washer. States washers not required for 1968 up.
                          Rich[ATTACH=CONFIG]115936[/ATTACH][ATTACH=CONFIG]115938[/ATTACH]
                          Rich-------
                          No GM valve cover reinforcement was ever of this exact configuration but these should work fine.
                            Duke------
                            As you say, for 1969 the L-46 was "SHP" since there was no LT-1 available. For 1970 the L-46 became "HP" since there was an LT-1 available which was then "SHP"
                            The last time before 1970 I can think of that "HP" was used for a small block was 1963-65 (when the base engine was 250 HP) and the L-75 300 HP was carried as "HP".
                            "HP" was not used as an engine designation again for Corvettes after 1970.
