Re: Wanted: Close-up photo of fuse GM #148511 (prior to change to colored version)
SFE type fuses are not the same as AGC. SFE are designed to prevent the wrong type of fuse from being used. The length of the fuse is determined by the amperage rating. Higher rated fuses are longer. A fuse block that uses SFE fuses would therefore have different length cavities.
