I am working on my differential (1980, 4-speed). In particular, the Posi unit. No issues, just thought the time has come for an overhaul.
For the posi unit I'm replacing the internals; clutch packs, thrust washers, and cross shaft/c-locks. All the gears look fine.
I'm a little confused; the posi unit has no internal shims. In particular, shims for the side gears/clutch packs. The service manual for a 1980 indicates no shims.
Question: How do I confirm/verify my posi rebuild was done properly?
Thanks.
Thanks.
