1963 cp rear window molding clips by Keen parts - NCRS Discussion Boards
  • Bob W.
    • December 1, 1977
    • 799
    Has anyone used these clips? Keen states they are 1/32'' longer to fit modern weatherstrips. I have original molding and repo weatherstrips.
    Thanks Bob
  • Scott P.
    • April 30, 1992
    • 178
    Re: 1963 cp rear window molding clips by Keen parts
    Bob a customer had his 63 coupe repainted which included removing the glass and replacing the weather striping. Which they did and put the stock clips for the SS back in too.
    I got the job of reinstalling the SS trim.
    Which was impossible because the thickness of the rubber would not allow the SS to clip in.
    So with much turpitude I taped off the glass & new paint and took a grinder to the rubber.
    Success in the form of attached SS trim and no damage to anything occurred.
    I took the rest of the day off.
    Longer clips certainly would help make the fitment easier. Or get your grinder and tape out.
    Scott
    • Bob W.
      • December 1, 1977
      • 799
      Scott thank you for your reply. Someone else posted about shaving the weatherstrip sometime ago I had hoped someone had used the longer clips. At some point I will give Keen a call to make sure they will work with the original SS moldings.
      Thanks Again Bob
