Battery disconnect and C-7s - NCRS Discussion Boards
  • Lynn S.
    • May 5, 2016
    • 105
    Any suggestions on how to preserve all electronic functions if indoor judging facility requires that you disconnect the battery per the local fire marshal? Doing some Sportsman entries in the future at indoor events. Checked out Battery Memory Saver option. These rely on 9 volt batteries with a 2 hr max life. Any thoughts? Thanks in advance for replies.
    Lynn Skipper 62393
    1995 LT-1 Polo Green conv. w/ Beige/Beige, Chapter Top Flight
    2018 LT-1 GS conv w/ Kalahari/Black, Heritage pkg, 2LE, 8sp w/ paddles
    1975 L-48 Steel Blue conv, w/ Med Saddle/Med Saddle, 4 spd, C-60 current project.
  • Mark E.
    • April 1, 1993
    • 4498
    Re: Battery disconnect and C-7s
    I've never used one if these, but it's designed for your intended use. I'm not clear why hooking this up is safer than using the car's battery, but the vendor claims it's fire marshall friendly.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Lynn S.
      • May 5, 2016
      • 105
      Thanks Mark. A little too costly for me. I'm curious what C/5 thru C/8 owners are doing for judging events that are completely in doors and over night to meet the Fire Marshal disconnect requirement.
      Lynn Skipper 62393
      • Ken R.
        • August 31, 1980
        • 302
        I just have not disconnected my c8 battery when I have had it inside. I didn't do the c7 either. C8 is a bit easier to disconnect as you can get to the battery in the frunk than in the c7 at the back. If FM is going to be real picky on disconnect, I just will not put my car inside. So far has not been a problem.
        • David H.
          • June 30, 2001
          • 1485
          +1
          Why I don't put my car inside - just avoid the problem.
          Dave
          p.s. Situation with battery cut-offs in any case, regardless of year.
          Good: keep you from a wiring problem becoming a catastrophe.
          Bad: keep you from knowing you have a wiring problem.
          • Lynn S.
            • May 5, 2016
            • 105
            Thanks for your reply Dave. As a usual Sportsman entry, most times, we are relegated to parking outside. So we'll see how things go in French Lick this summer.
            Lynn
            Lynn Skipper 62393
