Correct front spring height - NCRS Discussion Boards
  • Anthony C.
    • March 21, 2022
    • 207
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Correct front spring height
    Anthony, there is a procedure in your AIM concerning "ride height". Follow the procedure (diiferential measurement of 2 points on the front suspension) to determine the cause. You may have a front right spring that has become weak........
    • Anthony C.
      • March 21, 2022
      • 207
        • 11608
        If you look through old threads you will see that this is a very common occurrence.
        They weren't perfect from the factory.
        • Anthony C.
          • March 21, 2022
          • 207
          • Gary B.
            • February 1, 1997
            • 6979
            Anthony,
            I don’t know where the battery is located in a ‘75, but a battery, and an AC compressor unit, and other one-sided, heavy things can result in different weights on each front side, and result in different heights side to side. Also, what is the side-to-side +/- spec for height in the ‘75 AIM? For ‘66 it’s 0.25”.
            Gary
            • Mark E.
              • April 1, 1993
              • 4498
              Originally posted by Anthony Cammaroto (69061)
              Thanks pat .. I was going over the car getting ready for spring driving and never notice it until now .. I know they weren’t perfect but I feel 28 and 5/8 of an inch is to high .. Shouldn’t the front be a little bit lower than the rear or at least level
              As Stephen advised, AIM has specs and tolerances for ride height. You might check it out.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Keith M.
                • January 17, 2021
                • 663
                A concept that should be remembered and applied to all aspects of "judging".
                late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
