On a 69, should the dash harness go over or under the steering column? The AIM shows it running below the speedo and tach and that's where the J-clips are located but it ends up in the way of the column. To run the harness above the column will require bending a loop into it and my current harness has no such loop but I can't say for sure whether it ran above or below the column.
I managed to get the column in with the harness below it but it seems to be in the way there too so thought I'd ask before finishing the column install.
Jack
Jack
