Hood Release, 1966 Coupe w/air. - NCRS Discussion Boards
  • Larry T.
    • January 12, 2009
    • 5
    This is the hood release on the left side of the steering wheel.
    I NEED HELP,
    I have tried a unit that I bought from California, (different than original, supposedly a replacement), I have mutilated a unit from Paragon. Something is just not right.
    I have checked an assembly manual to no avail. I have checked resources to no avail.
    Have there been discussions in the forum about this matter?
    Any help will certainly be appreciated.
    I'm at wits end.
  • Leif A.
    • August 31, 1997
    • 3607
    Re: Hood Release, 1966 Coupe w/air.
    Larry,
    Not clear what you need help with. A clearer explanation as to what issues you're having. Installation of the hood release is pretty straight forward.
    Picture of a hood release for an A/C equipped car:
    Picture of hood release without A/C
    Leif
    • Don H.
      • December 1, 1981
      • 1482
      The bracket that holds the hood release lever is longer on an AC car than non-AC (to clear the AC vent).
      • Larry T.
        • January 12, 2009
        • 5
        I too thought this would be a simple replacement, however, it has turned into a nightmare. I ordered a wire/w handle and yes it is longer, I have shortened the wire and when I pull the handle it bends the wire and I am very afraid that I will be caught somewhere and pull the release and the wire breaks.
        It does not appear to be a simple slide.?
        • Michael G.
          • November 12, 2008
          • 2155
          I have had the same problems. These releases have never been great: all of them bind to some extent, but the repros certainly work even worse. Its a bit frustrating to find the handle loose in your hand, with the hood still latched.
          I recommend that until you get the repro part to function properly you attach a second, (back-up) wire to the release lever then through the hole in the dash, with a loop under the dash, so you can pull it by hand, if the repro fails. I even leave the second wire there permanently on my non-judged cars.
