I have done a search on this topic but wanted to get the opinions of the knowledgeable members that frequent the forum.
I recently purchased a 1969 L89 project car. I'll be posting that journey on here when I get a bit of time.
I have the POP and on the POP the engine assembly date is Oct 20, 1969
The trim tag build date is Oct 31, 1969
I have been looking for a date correct block and thought I had found one with a Sep 5 69 cast date. In my mind that would be perfect.
However, the engine rebuilder stated he would like to find a block closer to the build date.
I told him that I thought the standard bore 512 Sep. 5 block seemed perfect, no need to look.
Well, I got a call yesterday and was told he had found a block (standard bore) with a cast date of Oct 14 69
He said it was perfect and that I'd "never have to defend the car with the judges with this block".
My question is this: Is 6 days from cast to assembly to close?
He is adamant it isn't.
. Plus, it looks like engine assembly is the critical path in the date sequencing - castings apparently were available on the same site, but assembling them across the way was taking longer - hence the date spread.
