What is correct length of the four bolts that holds the rear spring to the differential? I bought a nine-leaf aftermarket spring with the liners installed. The spring stack measures 2.66 inches. The vendor said to use 4-inch bolts but to me that sounds a little bit long. I don't have the original spring to measure the stack height, nor do I have the old bolts. So, if someone could tell me what the original spring stack height is or what bolts to use with the aftermarket spring, I would appreciate it.
Danny
Danny
