1960 Accelerator Return Spring Bracket - NCRS Discussion Boards
  • Pete P.
    • March 1, 1992
    • 103
    I have a 1960 Corvette with the base engine, single 4bbl, 230 HP. I've must have searched through the 1960 Assembly Manual a dozen times looking for the return spring bracket. Section 6, sheet 9 of the AM calls out the return spring P/N, but not the bracket. The bracket shown appears to be what I have on my car, but is incorrect for 1960. I believe what I have is a bracket for a '56. The JG, page 190 and 191 show the correct bracket. Where in the AM is the correct bracket shown and P/N?
    Thanks, Pete
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 1960 Accelerator Return Spring Bracket
    Pete,
    I believe that was painted orange at Flint engine plant, so it would be part of the engine assembly and not be broken out in the AIM.
    • Pete P.
      • March 1, 1992
      • 103
      Thanks Mike. Here's a photo of the bracket on my car. Do you know what year Corvette this bracket belongs to? Pete
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Pete, Yes, Mike's on it, it was painted orange because it was installed at Flint Engine assembly.
        What does the JG show, photo please?
        Edit- Yours appears to be non-Corvette. Maybe Pass car or Truck.
        Here's a base engine '59 I did some years back. I believe the return bracket to be original.
        Vendors show it as 1956 to 1962E 1X4 . The GM part# was 3729808, 2 are used on 2X4 WCFB, 1 on 1X4 WCFB
        DOC Rebuild
        Corvette Central
        Zip
        • Pete P.
          • March 1, 1992
          • 103
          The 1960 JG shows the bracket like in your photo. Here's a photo from the JG. Pete
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            Pete , Ok thanks for the JG photo. That confirms it.
            Rich
            • Pete P.
              • March 1, 1992
              • 103
              I tried to loosen the thermostat housing bolt because I want to replace the bracket with the correct one. The bolt is not budging and I'm afraid to snap it. Any suggestions?
              Pete
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Pete do you have a battery powered impact driver? That helps.
                If not, try to tighten a bit, then loosen. Back and forth. Go easy.
                • Pete P.
                  • March 1, 1992
                  • 103
                  I don't have a battery powered impact driver; just an air-impact one. I'll try the back and forth tightening/loosening method with a socket as you mentioned.
                  For the heck of it, I just checked ebay and found a listing by Richard Fortier selling a bracket like the one I have in the photo above. He lists it as a 55-56 Corvette bracket. I must have bought mine from Paragon probably in the 1980's not knowing it wasn't the correct one.
                  Mike and Rich, Thanks for the help.
                  Pete
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    I'd try the air gun, lightly back and forth too.
                    • Pete P.
                      • March 1, 1992
                      • 103
                      I'll give that a try also.
                      Pete
