I've read numerous posts about turning the steering wheel lock to lock and turning back 1/2 the total turns. However, when turning right, the pitman arm hits the power steering ram bracket (on the frame) about 1/4 turn before I reach the same number of turns as going left. Of course there is no adjustment in the placement of the bracket.
Months ago I had the gear box rebuilt. Before removal of the gear box I marked the shaft and the pitman arm. If I got this alignment off by one spline, would this be my problem? I'm 99% sure this is the correct box (5677849) as confirmed by Joe Lucia in an old post.
When I reinstalled the gear box, I replaced both sides of the steering shaft coupling. There is no flat on the gear box shaft, only on the steering shaft. I don't recall seeing an index mark on the end of the box shaft, but the pitman arm is pointed straight forward when the steering wheel is centered. The flat on the steering shaft is at 12 o'clock.
I'm hoping to avoid removing the coupling, but that will be the only way to look for a mark on the gear box shaft. I had no alignment related issues before repairing/replacing all front-end suspension components. I discovered this when preparing to reinstall my rebuilt steering linkage.
Maybe you folks can tell me what's up.
Mike
Mike
