Hello All,
Im looking for help again, this time with my EGR Valve. Im gathering up parts to get the system back together correctly, right now I am trying to get the EGR Valve apart. It looks to me like the sleeve in the bottom (manifold side) will unscrew and the vacuum actuator can be removed from the cast iron mounting block. Is this true?
I have been applying PB Blaster for better than 3 weeks. I used carb cleaner and a brush to remove carbon between the sleeve and the block, a bit of heat from a Map Gas torch, some 'love taps' with a hammer - I still cant get it to turn without damaging the sleeve.
Am I just going about this the wrong way?
Maybe I need to make a tool that will fit the two notches in the end of the sleeve?
As always - thanks for any help!
