The restoration battery in my 72 LT-1 was getting long in the tooth so I ordered a new one, which as has been discussed is probably a 6 month wait. In the meantime I bought a Walmart battery to tide me over. It works great, but on two occasions (out of probably 10 or 12) the battery boiled over after a 10 mile drive. I put the old battery back in, which was still functional, and checked the voltage. When I got home from my usual drive it was showing right at 14 volts at idle. I checked it again this morning after letting it sit all night and at fast idle I got a reading of 14.68 volts, which seems high. All connections and wires are clean and appear to be in good shape. Assuming the (original) alternator is over charging can a good local shop handle the repair or should I find a shop that specializes in these old units? I guess another alternative is to try and fix it myself which I wouldn’t mind tackling if I could find the parts.
