69 Coupe hinge pillar weatherstrip - NCRS Discussion Boards
  • Philip A.
    • September 18, 2021
    • 94
    does anyone know which is the correct screw that goes into the top of the weatherstrip to secure it to the top of the hinge pillar. The one I took out and reinstalled sure is close to the top of the door glass. Might I add the AIM doesn't really help me. Pics would be appreciated as well
    TIA
  • Gary B.
    • July 31, 1979
    • 926
    Re: 69 Coupe hinge pillar weatherstrip
    I have 2-pretty original 69's here. I'll get a picture in the morning. Please.
    Gary Bosselman
    • Gary B.
      • July 31, 1979
      • 926
      Actually two screws near the top, or should I say, near the bottom of the windshield.
      The closest to the windshield is a pan-head, cross-recess screw, with a small rectangular sheet metal washer under it.
      Farther down the weatherstrip, is just a pan-head cross-recess screw. Both appear to be a black-phosphate.
      I'll try and add them into the 68-69 TIM&JG.
      Gary Bosselman
      • Philip A.
        • 94
        Gary thanks so much for those. But what I am need is which screw or type is at the top of the Hinge pillar weatherstrip nearest the top of the windshield.
        Maybe I should have started with these pics. The screw that came out/depicted seems like it will just spread its way thru the rubber and not aid in holding it secure.
        Notice how the glass is so close to it when installed and window up.
        • Gary B.
          • July 31, 1979
          • 926
          The 69 I have at the house, does not have a screw on either side there. Neither does my 68 coupe, nor my 70 coupe.
          I would be concerned about a screw there hitting the window and chipping it. Or tightening it too tight and hitting windshield.
          That trim screw was typically use on the wheel opening moldings on metal cars, back in the day. I wonder if that's a dealer inspired addition?
          Gary B
          • Philip A.
            • 94
            Actually that screw is a countersink type with the countersink type of washer. It is odd why the chrome top piece that seems original to the car due to its pitting would have a hole there for a screw. its beyond me why someone would add a screw there when adhesive seems to be suffice.
            Thanks for the help!
