Need Help to Identify a Schwitzer Fan Clutch - NCRS Discussion Boards
  • Dennis H.
    • September 30, 2005
    • 226
    Hi
    I have a Schwitzer fan clutch that came to me in a group of engine parts when I bought my 65 project car several years ago. I always assumed it was original to my 65 300hp car but now not sure. The date on the clutch shaft is SO 3-25-66
    Would this be a correct OEM 1966 fan clutch.
    Dennis
  • Mark E.
    • April 1, 1993
    • 4498
    Re: Need Help to Identify a Schwitzer Fan Clutch
    Dennis,
    Tony Stein contributed an article on mid-year fan clutches for the current edition of the Texas Chapter's newsletter. It includes a few photos of what looks like your clutch. I don't know how to attach this PDF file, but it can be downloaded from ncrstexas.org.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Kurt K.
      • June 30, 2004
      • 194
      I would agree, looks correct for a 66 built after 3/25/66. The hub shaft length will determine if small block or big block application.
      • Dennis H.
        • 226
        Thanks Mark & Kurt
        I couldn't read that newsletter due to not being a Texas chapter member, I do know this is for a SB so looks like 1966 SB is the correct application.
        • Mark E.
          • April 1, 1993
          • 4498
          Originally posted by Dennis Hendrix (44677)
          Thanks Mark & Kurt
          From Stein's article:
          "This type was used for both small block (part no. 3814560) and big block (part no. 3857531) cars. The only difference between the Schwitzer small block and big block units is the length of the shaft. The small block shaft is 1.8 inches long whereas the big block shaft is 1.5 inches long."
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Ed S.
            • August 6, 2014
            • 1377
            There are three articles on C2 fan clutches in the NCRS Database of Restoration documents - one of those may help to answer your questions.
            https://www.forums.ncrs.org/showthre...tion-Documents
            Ed
            • Dennis H.
              • 226
              Thanks, measures out at 1.5" on the shaft face to clutch housing so looks like a 1966 427 Schwitzer fan clutch dated SC 3-25-66 (March 25 1966)
